Софт для StarTrackSRT-2014 HD DELUXE CI+
FAC.STARTRACK.SRT2014_HD_DELUXE_CI_PLUS_V3.02.16
Список изменений.:
[hide=2][/hide]
Список изменений.:
1. Infobar blinks on channel change : solved
2. Software protection : Added
3. Random receiver hangup issues : Solved
4. Channel Zapping speed : Improved
5. Turn ON/OFF subtitle while playing any media file from USB/HDD : Added
While playing media file press MENU and Subtitle Display ON/OFF
6. Subtitle with special character lead receiver to hangup : Solved
7. IPTV+ quick RCU button : Added (press tick mark key and hold)
8. PowerVU patch keys updated (MCAS plug in install required)
9. AVANT IPTV hangup issue : Solved
10. While scanning multiple satellite in Blind Scan mode, display the name of satellite being scan : Added
11. UPC Thor channel fast scan mode : Added
12. Russian language : Revised
13. USB not recognize if turn on receiver from STAND_BY mode : Solved
14. Youporn problem : Solved, download the addon from freetv+ menu
15. Minor S/W issues clear.
16. Transfer receiver CRASH_logs to USB directly : Added
Connect a USB with software inside and wait for software download windows to open and press the RECALL Key
after that connect the USB to computer there will be file with name "dmesg.log" thats the receiver crash log file
