Прошивки,инструкции GTMedia V8FINDER PRO
17/11/2021
Change log:
1. SNR menu, add signal buzzer sound
2. Increase C/N MER
3. In the INFO interface, add a YouTube QR code
4. Add ATSC-C (J.83B) menu
5. Add USB backup function
6. Update Polish
7. Add DVB-S2 adjustment method
8. Add NIT search menu option under DVB-C
9 Add radio channel list menu
10. Increase the system reset password 0000
11. Repair wifi connection, reset stuck problem
GTMedia_V8FINDER_PRO_release_V297_20211117.zip(5.65 MiB)
